It doesn't matter whether they are hooked up to open air or the intake tubing; It's the same thing! The intake tubing does not pull a vacuum on them, therefore it does not make a difference! The reason you get oil coming out of there is because the baffle design SUCKS and the situation worsened if your engine has excessive blowby.
You must be confused, the 3.1 is NOT set up stock to have vacuum on the valve covers and crank case.
I need my timing belt and accys replaced in about 1k miles or so, and the breathers are safe?
