Hi all having a problem with my 95 gtp 3.4 dohc. I had to replace the head gasket due to failure while it was apart I sent the heads out to be dolled up got it all together used my new cam setting tools so the timing is right on, It runs great when cold but like crap when hot? Any ideas where to start looking? I have read some things in the forums about the trouble shooting codes my problem is how do I get the codes out of it? And do I need to buy more stuff?
runs rough when warm?
runs rough at idle and when you are getting on it but only runs bad once it's warmed up. I gave it some new spark plug wires in hopes that would clear it up and it was no help. Also had a freind try pulling any codes he could out of it but there were none to be had. So I am at a loss of places to look for the problem
I always just go to the junkyard and get a bunch for like $5 a piece. Bring a multimeter along to test coil resistance. You can tell if they're no good just from that. Out of five OEM parts from the JY for the price of a new one you'll last a lot longer than the aftermarket crap you get at Autozone..
Is that the sensor in the side of the Head? It has no power when warm the exhaust sounds bad when warm vs when its cold it runs great sounds great. The temp guage seems to work fine so would that mean the temp sensor is ok? Im going out to pull the Coil's what should the reading be on the meter for a good coil vs a bad coil ?
I think the one in the head is for the gauge and the one in the TB is for the computer.
My car gauge would work, but I got error 117, temp out of range, and to find out TB temp sensor unplugged.95 MC Z34 Black
I got it
It runs AWSOME for the last week or so. Turned out my spark plug wires were cheesd out on me so I replaced them but managed to screw that up and got 2 cylinders crossed
. It was worth doing this all myself I learned alot about my car and some new swear words to boot
Thanks for all the help Bill
