i recently put a 50 shot on my z34 and when i use it my engine generates more heat than the cooling system can compensate for. the temp guage goes to halfway after 15 sec. of using it. any idea's on the direction i should take on upgrading my cooling system and are there aftermarket hi flow water pumps for this motor?
FYI: the jets i was told to use were 37 n2o and 22 fuel. and i have sprayed it 2 times. probably won't use again until i can increase the efficiency of my cooling system.
. i have to read the plugs tomorrow but i am confident. now comes the final phase of fine tuning. which consist of backing off of the fuel jet until the lean condition comes back and go 1 step up. what is the signifigance of the 1.5 ratio? cause as of now mine is 1.1!!! should i continue tuning until i can achieve 1.5 n20 to fuel ratio and sacrifice driveability? i gotta giv a shout to pocket-rocket. thanx.
I would just run it at the 1.5 ratio instead of messing around with a possible lean condition just to stay on the safe side. All of the horror stories you hear come from people that didn't set up their system right, and blew their engines (read ran them too lean). N2O is very safe power when set up right. It has been used for over 50 years now, and anyone who has had it that long that sets their sytem up right will swear by it that it is not a destructive way to get more power. Also it is not recommended to go more then 33% of your stock engines power if you haven't upgraded the internals to stronger materials, like forged pistons and rods. Everyone I have heard from on the DOHC feels that a 75hp shot is the limits of safe reliable use on stock internals, so I would stay at 50 if I were you. Thanks for the shout out, lol. Glad I could help and that you didn't blow your engine
