Well i have been wanting to bore the block .20 or .020..sorry people have told me different. But i am doing a complete teardown and rebuild. I found this kit and wondered if it was a good deal and if i was missing much.
I want to do a slight performance upgrade and get some more pep. im kind of on a 800 dollar budget..but i may go over that
Im still hoping to d some PnP work, heads will come later, and i hope that ben finds the 70mm tb.
Here are some pics of my rebuild and teardown: www.cardomain.com/id/fatheads34
Matt,
Master rebuild kit contains the following
Pistons (yes, you can get .020 o/size pistons & rings)
Rings
*Full gasket set
Rod bearings
Main bearings
Cam bearing
Timing belt
Oil pump
Freeze plugs
* Gasket set contains the following gaskets:
2 head, 6 exh manifold, 2 water outlet, 5 o-rings, 24 valve stem seals, 1
plenum,
1 timing cover, 2 oil drain plug, 1 rear cam cover, 2 valve cover, 2 int.
manifold,
1 oil cooler, 1 oil manifold, 2 o-rings, 2 EGR valve, oil pan, timing cover
seal, water pump,
2 cam housing, 1 rear main seal, 5 interm shaft seal, 2 cam rear cover
This is all the gaskets required to rebuild the engine.
Email your zip code and we will calculate the freight.
Thanks,
Joe
----- Original Message -----
To: <lowesville@charter.net>
Sent: Friday, March 12, 2004 10:26 AM
Subject: Engine kit
> http://www.lowesville.com/prod25.htm
> 91-95 V6 3.4L Eng Vin X (Less Cam & Lifters) $477.38
> I was wondering what all came in the kit. Do you have a list of every
gasket that is in the kit?
> I am trying to find a kit that has everything i need.
> can i get .020 pistons and rings in this same kit?
> thanks
> matt
Rings
*Full gasket set
Rod bearings
Main bearings
Cam bearing
Timing belt
Oil pump
Freeze plugs
plenum,
manifold,
seal, water pump,
Thanks,
Joe
Subject: Engine kit
> thanks
> matt
what kind are the pistons?? Silvolite
> is the oil pump hi flow? No, but it includes screen
> are the gasket fel-pro? No, Corteco. Felpro additional $25.00
> do i get the timing belt acutator, tensioner, and idler pullies? Timing Belt only
Manufacture recommends replacing the head bolts #27324 $20.00 set
We accept most credit cards.
Freight by UPS ground: $16.00
Transit time: 2 business days
Thanks,
Joe
Thanks,
Joe
Ill have final pricing on my site when its all said and done. I do plan on discounts for sets, so that 70-75 for the lower alone will probably be cheaper when done with the plenum/TB.
