milzy motorsports has headers for 96-97 monte carlo 3.4 i was just wondering if they would work on a 95
headers on a 95 lq1
Ports won't match, but you can swap to the later heads and intakes.
tim1995 Z34 - T04E "60" trim, 42.5 lb/hr injectors, AEM WBO2, FFP UD&DB, 3" exhaust, 2800 stall, shift kit, tranny cooler, Powerslot, Hawk HPS, rear disc conversion, KYB, Eibach, HMS F&R STB, Fittipaldi Force 18" wheels, big stereo, lots more coming eventually...
325 whp 350 lb-ft
I HIGHLY recommend swaping to the 96-97 heads
-higher compression & more efficient
Thats what I use...
If you need a set of 96-97 heads PM me.1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
And more if you use the 96-97 heads with the 95 and older style pistons, especially on a 91-93 3.4 DOHC with the manual.1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
Thats news to me. 9.25:1 for 91-95, 9.5:1 for the 91-93 manual cars (different pistons). The older pistons and the newer pistons probably won't change compression but I haven't cced both to verify. I think the compression to gained from the heads alone, which are 51.5cc vs 54cc for 91-95 style.
While the 96+ have a .040 dome, they also have more valve relief cut out. This is why I guess they are about the same compression wise.Ben
Exactly Ben,
The original piston in the 96-97 engine have differences in depth. You can tell just by looking at them. The compresion is increased with the old piston design BUT I found you got to be careful when buying them because I found that some companys make one style for even the older 3.4 dohc engine's just varying in the dia. but with the depth and top of a 96-97 piston, which sucks.1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
By my calculations, using 96-97 heads on a 91-95 automatic will go from 9.25:1 to 9.57:1. The rest is from the 96+ piston. 54cc head 3.1cc piston relief for the 91-95 auto, 3.700" gasket bore and .060" thickness. 0 deck height for the piston. Making it 51.5cc like the 96 head requires the piston have 2cc relief for 9.71:1 compression.Ben
