ok, my guys at PDQ couldnt get me more aggressive regrinds for my 3.4L DOHC. DOES ANYBODY KNOW, who can do regrinds for a more aggressive set up with my build. its not gonna be built for drag its gonna be a street machine.
CAMS!!!! HELP!!!
Comp cams will do it, but it's a bit costly. They will also ask you a lot of details about your engine and what you want to do with it, and they will design a specific grind around it. Just make sure going in you know your compression ratio, combustion chamber size, piston height, actualm displacement, things like that.I may own a GTO now, but I'm still a 60V6er at heart.
Wasn't there a company that did Northstar cam regrinds that would regrind ours for about $100/cam?-60v6's 2nd Jon M.
delta cams.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
know what? about delta cams or anything to do with DOHC's?
Andy
i just figured delta cams can regrind anything if it's a solid cam (no pressed lobes).Andy
That was the rumor. There were in Florida somewhere. An old ClubGP member found it when he did a Northstar swap into his GP. I don't know for sure that they ever reground a set of 3.4 cams or not. But they had 5 stages of Northstar cam so I would assume that if they could/would do it, you would end up with one of those specs.Wasn't there a company that did Northstar cam regrinds that would regrind ours for about $100/cam?I may own a GTO now, but I'm still a 60V6er at heart.
And I wouldn't trust anything from said Club GP member as far as I could throw the Titanic... Well that sucks.-60v6's 2nd Jon M.
CHRFAB outsources to a company called Steve Long Racing. they have done 2 sets before that i am aware of. I would try to stay away from CHRFAB. The guy is a complete ass to deal with and is hardly ever around.The Official Rotating Mass Nazi
you wont get much performance in the way of reground 3.4 cams. Since the majority of change comes from grinding away at the base circle of the lobe (the backside), you are limited on 3.4 cams that have very little backside to remove in the first place.
I wanna say its like less than 3/16'' , where as 3.1 / 3100 cams have over 3/8''I modify stuff
