Wheel horsepower is actual power put down to the wheels. It is less any drivetrain losses. A transverse mounted (FWD or Fiero) manual transmission will usually lose b/t 15-20% (I've found 18% to be closest). An automatic will be more like 25%. So the 178 you got is almost exactly 17%. My '95 GTP engine (auto) dynoed at 156, which is 25.5% of the 210 rating. The 190 you got is actually 229 at the crank, so you gained about 15hp over stock.
BUT, I bet if you look not only at the change in peak numbers, but at the at the rpms where the new peak occured, and the numbers above peak hp, you will see alot more than the 15hp. Dyno results can be deceiving when you focus too much on the numbers. I just built a 3" exhaust system on a Dodge Ram SRT-10 (Viper-powered) and it only picked up 20 peak hp at the wheels. BUT it picked up 40 horse power AT THE WHEELS at 6000, 800rpm above the peak. If you look at your graph again, I'm sure you'll see what I'm talking about.
I, too, used an angle finder to check the flats on the cam. I had a degree wheel, indexed the cams to the cam carrier, AND used the angle finder to triple check everything. Mine is turbocharged so I left the exhaust alone and retarded the intake 10deg. to reduce overlap and raise the rpm range.
