I seen that you made the chip, but do i really need to change the timming or do you have a chip for stock timming.
chip options
I have stock timing tuned no problem. Remove the screen but not before the chip. I mean, you can but it does throw the computer fueling off which is why I went to the trouble of retuning the fueling for the screenless setup.
I was hoping to have dyno results this week, but it will hopefully be next week as this is all up to whenever Chris can take his car to the dyno for me. Also, the shift points will be up to you. I can recommend settings but its up to your tastes and how much your transmission likes you:PBen
thats good but what kind of shifting points do you recommend for a 4t60-e that has higher mileage.
Im hoping to run tens in the 1/8 if I can, Im already running a 10.6 so would this chip really help with that?
1995 3.4 DOHC Grand Prix gtp
cold air intake, high flow cat, dynomax mufflers.
I don't know how it effects 1/8 mile. The only track difference I know of includes 6/6 cam timing and wasn't the final tuning (was too rich at the time).
I can leave them stock, or raise them a small amount other than 3-4, which is 104 stock and 120 works great. Most people won't even care cause thats faster than they go, but its there anyway. Im willing to try whatever, but I take no responsibility for your engine or transmission. I will not do anything stupid either, so telling me you want first to hold till 60 isn't gonna happen:PBen
