For that spendy tool.
Freeing the cat and thus removing the backpressure opens up possibility that more unspent fuel will just get exhausted out. An EGR actually helps MPG if you have some fumes in the exhaust at certain times the egr can recirculate this.
It is not like you lose alot, again it depends on how you would drive it. Since the power band would be adjusted, if you follow that mileage would remain the same pretty much, with emissions like these cars have you would have to remove a few other things to notice any real improvement.
Like cylinder dropping on block learn with solinoid valve control to make sure the compression stroke does not happen on that cylinder. I came up with a design of a slider glide wedge actuator cam follower thingy
If you really want to get mpg the ECM coupled with all the emissions is your culprit.
