Does anyone know with certainty what the stock oil pressure is for the lq1? On gmpartsdirect they sell an oil pressure spring for 60 degree v6's that puts the oil pressure at 70 psi. I am considering adding that to my list of parts for the rebuild on my spare 3.4
lq1 stock oil pressure?
Are you sure that the spring doesn't regulate oil pressure? This is exactly what the description of the spring says on their site: "Oil pressure in V6/60º engines is regulated by a spring in the oil pump cover. This spring (color coded with a blue stripe) will produce approximately 70 psi oil pressure." I realize that pressure will vary depending on rpm, temp, motor tightness, viscosity, etc. But I figured the spring regulated what the max would be.
well the way i understood it was that if the oil filter were to become clogged or the pressure were to try and exceed 70psi the springs job was to bypass the filter to bring the psi back down to a safe level. but mabey im misunderstood.92 Lumina euro 3.4 DOHC 139,XXX miles
The stock TDC pump will provide all the pressure te engine needs. On top of that a tight motor will cruise around at 60-65 psi . The TDC pump is a form of HV HP pump already.Lorenzo
Okay from what I'm hearing there is no need to change out the oil pressure spring in the pump. I am getting a new pump as part of my rebuild and I'll leave it at that. However I think I'll buy a good oil pressure gauge so I can accurately monitor the pressure in the engine I am rebuilding.
