Everyone:
Well, it runs.....sorta.
For anyone who hadn't heard the story, last fall I decided to do a relatively mild build to a 3400, to replace the bolt-on-only 3400 in my 2000 Olds Alero. To say I got a little carried away is an understatement:
3400 block bored .040" over
Sealed Power hyperutectic pistons (and rings)
Balanced rotating assembly
1280 cam grind from the store (Stage 3)
Flowmatched street/strip 3400 heads with SS valves, Comp springs/retainers/locks
Ported upper and lower intake manifolds
S&S headers (ceramic coated) to replace leaky TOG headers
So anyway, it runs, but not very well. I think the FPR might be bad (at least, that the diagnosis of my engine builder). Here's why:
I am seeing very high MAP values at idle (~ 60kPa). This in turn causes my fuel trims to get way outta whack - STFTs eventually level off at +27, and then they naturally start to increase my LTFTs. We pulled the vacuum hose from the top of the FPR (which runs to the MAP sensor), and we can smell fuel. Fuel should not be in the vacuum line. So we'll try that. This same condition happens at cruise too.....and naturally, it bogs real bad off the line since it's drowning in fuel.
We did not notice any misfires or other DTCs, so that promising.
I'll have a video up shortly.
But if anyone has any thoughts on what else might be going on, I'd love to hear them.
