My dilemma is that I need to replace the front wheel bearings and I believe the spec is around 180 ft lbs for the axle nut, my 1/2" drive torque wrench maximum capacity is 150 ft lbs.
I had the wheel bearings out last year so I could pull the axles through the knuckles - on the reinstall things got interesting.... Not having a torque wrench suitable to the task, I got creative. I took a long piece of angle iron and welded an old socket on one end and a 1/2" drive on the other. With the help of my father (engineer/math wizard) on the math we came up with a formula to determine how much torque I needed to apply on the socket end to get X ft lbs of torque on the drive end - the stipulation was that the torque wrench had to run parallel to the angle iron. This meant I could use my lower capacity wrench to suitably torque the axle nut. Now a year later my wheel bearings are beginning to hum down the highway - sure this could be 18 yrs and 122k miles of wear, or it could be that, the math or physics behind my method or torquing was incorrect.
Assuming the math is correct, does the above theory seem sound? Do the physics of it seem right? If not, any recommendations for a high capacity ~250ft/lbs torque wrench that doesn't break the bank? I really only need it for this one thing (axle nut) which is why I don't want to drop a lot of coin - most every other fastener on the car is within my current wrenches capacity.
