Well i got a new car and i could use some help you guys know these motors quite well and the thing is im mix match motors that are not really very close to be the same.
i bought a 1978 Datsun 280z 2.8 lt even-fire fi motor 5 speed transmission. BUT im going to be using a 60 degree v6 ecm/ecu, engine harness, crank trigger - and sensor, as well as the ignition control module (icm) as well. it will be running in batch fire so i will not be needing the cam position sensor (cps).
pictures of MY car.
pictures of the guy who first did the ecu harness and all swap.
now what im not sure about is about the crank trigger. any ideas there? this engine never had a crank trigger obviously.... so yeah... oh btw the purpose in the swap is so i can tune the motor (going turbo probably gt28rs or just a t3/t4) using a moates setup.
pictures of MY car.
I can't help you on your project, except by saying that the CPS mount the guy made doesn't seem like it would be too hard to fabricate. Have you dropped him a line to see if he can make you a setup?
