Got chip from FFP designed for 180* stat, and EGR valve OFF. I decided I would get my car tested with it off and see what it does. And oh man, how I failed. The numbers are hard to see but they're there.
First Run FFP chip
Numbers
Test 25/25
----------Tested/Allowed
HC ppm 15/114
CO % .01/.63
NOx ppm 1057/796
RPM 1688/2500
CO+CO% 14.9/ 8min
Test 50/15
HC ppm 16/117
CO % .01/.65
NOx ppm 1511/879
RPM 1786/2500
CO+CO% 14.9/ 6min
Second Run, immediately following the first I backed up installed the stock chip and went back at it. I may have failed because I didn't give the engine any learn time and the Cat had time too cool.
Test 25/25
HC ppm 52/114
CO % .04/.63
NOx ppm 432/796
RPM 1687/2500
CO+CO% 15/ 8min
Test 50/15
HC ppm 19/117
CO % .01/.65
NOx ppm 976/879
RPM 1804/2500
CO+CO% 15/ 6min
Third run stocker still in after 45 mins or driving.
Now this is interesting, same car, one year ealier, the only difference is I had stock chip and stat in. So really the only difference is stock stat. Don't know if the time the stocker was in would have changed anything.
What would cause that change?
First Run FFP chip
Numbers
Test 25/25
HC ppm 15/114
CO % .01/.63
NOx ppm 1057/796
RPM 1688/2500
CO+CO% 14.9/ 8min
Test 50/15
HC ppm 16/117
CO % .01/.65
NOx ppm 1511/879
RPM 1786/2500
CO+CO% 14.9/ 6min
Test 25/25
HC ppm 52/114
CO % .04/.63
NOx ppm 432/796
RPM 1687/2500
CO+CO% 15/ 8min
Test 50/15
HC ppm 19/117
CO % .01/.65
NOx ppm 976/879
RPM 1804/2500
CO+CO% 15/ 6min
