anyone have recommendations on injectors....here is the situation. i have decided to go nitrous also on my setup which now has the trailblazer 28# injectors. does anyone think i need to up the ante with some 32 lbers? im looking at a 75-100 (WHP is how harrisspeedworks rates them) shot. its going to be a dry system.
also does anyone think i should go wet/plate instead? If so, i guess i could get that TB spacer from MAP and use it to make a plate.
just in case no one remembers my setup....its an 02 3400 (meaning 55psi FPR) bored .030 10.2:1 with all the ported goodies running the 28# injectors soon. im hotwiring my fuel pump for now, may get the walboro unit later on.
i wanna make sure i can get enough out of these, or if i need more injector/should look at a wet kit
