how much boost will a stock fwd 3.1 motor handle??
how much boost will a stock motor handle
6 or so psi...-Brad-
*looks at avatar* Hmm, yep Ford Turbo coupe turbo, works well.Originally posted by AaronThose were only like 2.3L 4 cyliners, I'd say you'd need bigger considering the stock turbo on the TGP is on the small side.Originally posted by tjbechtok well what car should i get a turbo off of what about a thunderbird turbo coup
i did find that in my application it was probably a bit on teh smallish side, but there were other factors that are being changed along with the turbo I'm changing.
Don't assume by engine size that a turbo will be too small or too large, there are other factors involved.
I wouldn't trust it with anything more than 12. Especially on the stock ignition/ECU. Hell Luke's TGP(running 11.5), HAD to run premium, and knocks slightly with anything less than premium.Originally posted by mcgavinz2613.76psi
anymore and you will instantly destroy the engine
93 octane, running about 16º total timing, for now. I'm going to start bumping it up, after I get a WB02
