Cylinder Heads 3.1 TBI
    replied
    oh. well then nevermind:P I like comparing off the same bench cause each setup is different. I use a tube for the exhaust and if you don't, those iron head 3.4 numbers look realistic for gen 2 for the most part.
    I can still send you the manifolds to do your own testing, I'll get repayment someway, lol. I cauld always bead blast the junk heads I have and cut them on our vertical drop-bandsaw, though The 3.4 numbers are not from you obviously, I have no idea how they or the 3800 heads were tested.
    replied
    Ah, maybe... I forgot we had 2 new guys from overseas sign up within a week of each other.
  • 1988GTU
    replied
    ^ Don't you mean Weba is?
    replied
    IIRC, he is coming over to the states in a month or so, so he could pick them up and take them back on the plane with him.
    replied
    replied
    I can get a head local probably but could use manifolds. Nice to see those numbers are close to mine. 3.4 DOHC pwns on the bench.
    Probably because some of them ARE your numbers
    replied
  • 1988GTU
    replied
    Shipping will be about 150.00 IIRC. lbs + size of those heads just adds up.
    replied
    I need to flow the iron head with and without the complete manifold setup someday.
    enough of the off topic though:P what would it cost to ship a set of heads to germany? I dunno what they weigh.
    A complete iron head top end weighs 84lbs IIRC, then you can subtract about 14lbs for the manifolds.
    I Could send you a head and manifolds if you want (the junk ones will work), but I already have flow numbers for stock and SuperSix porting - thanks to turboproject...
    replied
    replied
    I knew you would have a set:P
    Actually have a couple, but the other set is no better than boat anchors, lol.
    replied
    replied
    I have a set that came off my 3.1 and were running strong (blew the bottom end from turbocharging).
    I'll let you have them for a reasonable price, but shipping would be expensive.
  • 2.8RS
    replied
    I was going to say that a set of heads would be easy to find in a junkyard but I see that you are in Germany. But check out Ebay, there is usually a few heads for sale on there.
  • McLin
    replied
    I found this on:
    Rebuild
    FWD, APV, Transport, block #653, 519, crank #981, cast iron heads, with distributor.
