3.4 DOHC Throttlebody
From 96 motor, includes TPS and IAC
Clean and in good shape, no defects.
$35 shipped.
From memory I believe it is 64mm but I'd need to measure to be sure.
Includes the throttle cable bracket but this piece was modded as this was used on a different motor. You can use it, or discard and use your original bracket.
The backside of the TB plate is as clean as the front - it was ran on a motor that did not have an egr valve.
dohc is on left
__________________________________________________ ________________________________________
3.1 TB
The cover plate with the IAC air passages needs a gasket. Hence it is not bolted on. No IAC/TPS. I think this came off a J body but I don't remember for certain.
$15 shipped.
$35 shipped.
dohc is on left
3.1 TB
$15 shipped.
