Not insane, probably in the 10.x:1 range. 3500 heads are 32 cc and 3400 heads are in the 28cc range.
3500 Sfi For Sale(350.00)
So should I get 3500 heads for my 3400 block?
Then will the 3500 intakes all have to go on there?
I still like the thread about port and polishing your motor with the heads still on.
The guy who wrote that made it sound like it was the way to do it!
"....crank the motor up to 4000 RPM and slowly start pouring the white sand in the TB..."
HA!!! loved it!!!!!sigpicHow to make High performance Emissions:
It's unfortunate that this thread deteriorated to the previous tone, but I feel it necessary to mention that I just went and checked the cam in my 2005 3500 from the G6 currently upside down on an engine stand and noted that an approximately 8 inch long screw driver went all the way into that center hole until the handle hit the end of the cam. So I guess I didn't get one of those solid camshafts.Originally posted by FNJ26goooooood!cause none of you know anything!first of all the cam isnt the same for the simple fact that the 3100 and the 3400 have a hollow cam which was a problem with them breaking.gm corrected that problem with the 3500.look at the diffrence in torque between the 2.i guess that doesnt count for nothing either?
Couldn't you just have played "telescope" with it to determine that?
I think the roller cam failures is more due to the Leaking LIM than the cam being hollow.Originally posted by Joseph UpsonHa Ha, no it's still in the block, I didn't know GM had a problem with roller cam failure that's kind of scary.
Don't feel bad, I too have a 3500 cam and it is hollow. The 3500 cam is the same part # as the 3400 cam. However where it gets interesting is that the 3400 Equinox cam has a different part #Originally posted by Joseph UpsonIt's unfortunate that this thread deteriorated to the previous tone, but I feel it necessary to mention that I just went and checked the cam in my 2005 3500 from the G6 currently upside down on an engine stand and noted that an approximately 8 inch long screw driver went all the way into that center hole until the handle hit the end of the cam. So I guess I didn't get one of those solid camshafts.2000 Grand Am GT
2011 Chevy Impala
