What I think I know:
- 128 is optimal, meaning the computer isnt adding or subtracting fuel
- Above 128 adding fuel
- Below 128 subtracting fuel
- INT is locked at 128 on a cold engine for X amount of time until the o2 is responsive
Here are some examples of what it does on a 10 or so mile drive once INT is active:
-maintaining about 40mph on level ground, 6% throttle INT value 110-115
-easy acceleration from 33-55 mph, throttle steady at 20%:
MPH RPM INT
33 1750 124
40 2125 155
50 2650 132
55 2950 117
-deceleration sometimes makes the INT go crazy, I've seen it dip into the 70s when throttle is 0% and other times it stays around 128.
I guess I just don't understand what is the proper way for the INT to behave? Are these wide variations normal? I'd think a well tuned car wouldn't deviate from 128 too much. I'm even more blown away to think of how one tunes for the correct INT given the enormous combination of possible throttle/engine vac/rpm.
Other issue:
I'm still having a code 43 issue as well... the CEL comes and goes but never when the engine is up to temp. It usually happens at startup of a cold engine (maybe 1 in 10 starts) and there is no driveability issue. But, sometimes it happens on a warming up engine, like today I had 120* on the temp gauge (aftermarket, accurate) and the CEL came on at a stop light and the idle roughened up and dipped low but didnt stall. Check engine light went out before the traffic light turned green and the idle cleared up and no probs the rest of the way home. CPS is a few years old as is the wiring from CPS to ign module, coils and ignition module from late model 3400. I've swapped coils/ign module with another set and condition persists. I've suspected the knock sensor but I'll pick up less than a dozen knock counts on a normal drive (WOT is a diff story it'll detect about a hundred and pull massive amounts of spark on a jounce to 60). Sometimes it goes a week without a problem. But when it happens in traffic and the engine feels like it might quit it scares me.
MPH RPM INT
33 1750 124
40 2125 155
50 2650 132
55 2950 117
Other issue:
