I currently have a 95 grand prix 3.4 dohc engine swapped into my 86 Fiero runnign on a 90 TGPecm .. the auto tranny has been disabled for using the manual trans in my car.. and I had someone burn a chip that was tweaked to help it run the 3.4..
currently it will barely idle and is running pig rich.. I hooked up my actron scantool and wrote down a few of the recorded data logs.
when engine OFF
Throttle % 1 - TPS volt .52
Throttle %100 - TPS volt 4.41
Spark Adv -4
MAT 69*
02S (mv) 4
MAP 1.59
MAF 0
INJ pw 15
IAC 105
ESC 21
exh RICH
A/F desired 11
running with foot on throttle keeping it from stalling
RPM 1625
TPS v 1.04
throttle % 16
spark advance -4
02S mv 852
exhaust RICH
MAT 72*
MAP v 1.22
MAF 49
integrator 128
INJ pw 4
IAC possition 118
ESC 2
A/F desired 10
after goosing it
RPM 6000
TPS v .52
throttle % 1
spark advance 0
02S mv 804
exhaust RICH
MAT 70*
MAP v 0.35
MAF 33
integrator 128
INJ pw 0
IAC possition 118
ESC 19
A/F desired 13
knock ret 0
not sure exactly what info to gather to help diagnose the running WAY rich
any advice you can offer would be great.
when engine OFF
Spark Adv -4
MAT 69*
02S (mv) 4
MAP 1.59
MAF 0
INJ pw 15
IAC 105
ESC 21
exh RICH
A/F desired 11
RPM 1625
TPS v 1.04
throttle % 16
spark advance -4
02S mv 852
exhaust RICH
MAT 72*
MAP v 1.22
MAF 49
integrator 128
INJ pw 4
IAC possition 118
ESC 2
A/F desired 10
after goosing it
RPM 6000
TPS v .52
throttle % 1
spark advance 0
02S mv 804
exhaust RICH
MAT 70*
MAP v 0.35
MAF 33
integrator 128
INJ pw 0
IAC possition 118
ESC 19
A/F desired 13
knock ret 0
