As most of you know, I am building another engine for my three wheeler. http://60degreev6.dreamhosters.com/d...t=5750&start=0 It's a 3400 and will have twin T-25s, fabricated intake and a few other mods. Emissions testing is not a concern to me as it is registered as a motorcycle.
The current setup is a '95 Lumina 3100, 4T60E and ECM. My problem is "What ECM should I use?". I like having an auto and was planning to use a 16149396 ECM since I have the 4T60E. A transmission rebuild is in my plans as well as a stall convertor, so I have been considering swapping to a non-electronic transmission thereby eliminating the need for an ECM to control the tranny. This would allow me to use just about any ECM that would be compatable with boost.
Any ideas, thoughts, suggestions or input? OBD1? OBDII? Megasquirt? Keep in mind that I have a limited budget.
only took me 1 year to get him to do mine. ill get it tomorrow, btw, im psyched, but anyway, i believe those are also supported. you could submit a ticket to dhp about the ga with a vin number but i would go with the monte one as well.
