Let me provide some background info of my setup.
I'm currently using an Ostrich 2.0 and Socket Booster trying to emulate a 2732A on a 7170 ECM using TunerProRT v5. The Socket Booster is connected to a 24 pin socket that is soldered into the ECM. I have the 4 unused pins of the ribbon cable at the red stripe end.
+++Here's what's happening: +++
It seems the emulator will not work without the USB cable connected to the laptop.
When I start the car without it connected to the USB the Check Engine light turns on and I get no ALDL data.
If I connect the emulator to USB on my laptop, I’m able to start the car without problems; I get ALDL data and a PROM error.
+++What I have done/checked: +++
- I can connect and upload a bin to the Ostrich with no issue.
- I can successfully run the “Verify the emulator RAM contents with current BIN” with Tuner Pro.
- I performed a reset of the Ostrich with the DORESET app. Problem persist.
- I verified the pin setting on my Ostrich and problem occurs in both 28 pin and 24 pin emulation.
- I switched between 28 pin and 24 pin on the Socket Booster and problem still occurs.
- The “Test for Valid Interface Settings” of the ALDL on Tuner Pro always fails either with USB connected or not.
- I can put a stock chip in the same 7170, and I do not get a prom error, and I get ALDL data. The engine starts and everything seems to work fine except the tune is not set for the injectors currently installed.
- I have updated the firmware in the Ostrich, with no effect on the problems.
No matter what I do I can't get ALDL data without the Ostrich being connected to USB.
Could this be due to a bad socket booster? Is there anything else I could try?
I plan on picking up an Ostrich this spring/summer since I'm making some top end changes to my car this year. I hear nothing but good things about Craig Moates and his service.
