OK, figured I best start a thread on this.
Mods/car in sig, I'm using a Powrtuner for my tuning. I am running a 97 Venture PCM with a 97 venture DHP 1.5 file.
I have been reading a lot, learned about Eddie's tool on the Powrtuner forums so I am using that now as well. Bear in mind that I am still sorta new to this!
Was told that I should do a VE tune first, so I did the whole copy good spark thing, disable PE, and drove around and logged info. Plugged it into Eddie's tool (using all default options) and put it back into my BIN.
Now driving without my MAF plugged in is HARD. It is hard enough for the car to idle with my cam with the MAF plugged in, when I have it unplugged the car dies around every turn if I don't roll through the turn and gun it. It came to the point where I did 2 30ish min scans for VE, plugged in the data, and I am not going to be able to do anymore anytime soon. Almost got hit on the road a few times from stalling out.
VE is closer now, it could be better but I don't think I should worry about it anymore? I am within +- 5 last time I checked.
REGARDLESS I am onto MAF now. Did a cruise and did some changes, all seems well. Did another cruise and hit 4k RPM's and held it, wideband went max lean for a while till the computer could compensate. OK. Looks like I just need to do this more for a closer tune.
Problem is after reading a bunch, it sounds like tuning like this does not work for WOT, or anything over 7000hz MAF. I hit just over 7000hz MAF at 4k RPM's. Normal? I am afraid to push the engine any harder if the computer can't compensate fueling at WOT, I do not want to run 18:1+ at high RPM's.
Should I need to modify when PE gets enabled at all?
What would be the best way to add a good bit of fuel up top now, THEN go and drive and see how much I am off? I am positive I will be lean if holding 4k RPM's is ultra lean.
Do I need to mess with AE at all? I read what it is and I see people talk about it, but I just don't get what it is changed for and what parts are changed.
