Originally posted by robertisaar
View Post
Master pinout/16236757
some of the later PCMS measure the alcohol levels in fuel."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Until 3 years later and the rings are worn some and the tune slides out, then having the O2 pays off. As it's main purpose is to keep the car in tune after it ages....to help keep that perfect tune.Originally posted by ericjon262 View Postalso, it could be argued that with a perfect tune, you wouldn't need o2 sensors either...
though it isn't a perfect solution, it is better then how it was before O2's were used.
Otherwise, blowby and injector wear will wreck havok on the AFR after time.
But yeah, I run open loop most of the time.
Absolutely, and knowing how to filter that data. As a whole, that data is useless until it is broken up into usable chunks.Originally posted by unchained01 View PostI think the more info you have ther better the tune Either way
Its not about guessing its about tuning for the dataLast edited by TGP37; 03-26-2013, 07:54 AM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
I needed a new clutch switch that offers two open signals when the clutch is depressed, one for clutch anticipate, and one for cruise control. here is what I've found.
1994 camaro Z28 brake light switch
P/n on the back is 10424858
The rear set of four terminals are the ones I need. the front pair, and rear pair both perform as prescribed.
I'm sure you could use a relay to flip the switches operation.
If the switch is closed, adds voltage to the relay which opens the line. And visa-versa. You could also use two relays to operate from just 1 clutch switch as well.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
not sure if i would want to use a relay on something that can be this time-critical.[CENTER][B]1995 Monte Carlo LS[/B] 3100, 4T60E...for now, future plans include [B]driving it until the wheels fall off![/B][IMG]http://i598.photobucket.com/albums/tt68/robertisaar/NewSig.png[/IMG]
the switch swap was too easy to worry about messing with a relay"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Last edited by ericjon262; 04-14-2013, 03:55 PM."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
several new pins were added.
Second ignition feed
Air pump relay control
sensor grounds
5V referencesLast edited by ericjon262; 04-19-2013, 12:08 PM."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
good point. Especially using only 12v. Maybe a different story with 120v, but this isn't an RV...lolOriginally posted by robertisaar View Postnot sure if i would want to use a relay on something that can be this time-critical.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
again, the switch was too easy to implement to worry with a relay."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
edit:
removed...Last edited by ericjon262; 12-14-2013, 08:50 AM."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by ericjon262 View Postthe switch swap was too easy to worry about messing with a relayOriginally posted by TGP37 View Postgood point. Especially using only 12v. Maybe a different story with 120v, but this isn't an RV...lolOriginally posted by ericjon262 View Postagain, the switch was too easy to implement to worry with a relay.it seemed like you missed a post in there. the switch swap really is cake though, 1 wire to the PCM, 1 wire to ground, done. should probably wire in a cruise clutch switch too, but that's also easy, just piggyback off the wiring on the brake cruise switch.Originally posted by TGP37 View Postagain....?
should be 2 solid yellow wires on the brake switch, cut one, then wire both cut ends to a switch similar to the one pictured above, any normally closed brake or clutch switch should work. nice thing about the one pictured earlier in the thread, is that is has two switched that both do what we need built into one, which makes packaging way easier."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
