Well, I'm going to put aside the ignition (hardware) issue for the moment until I get a fresh battery.
But, now I'm having an issue with TunerStudio and the ignition (software) setup. According to the MSefi directions for the DIS, I'm supposed to edit the maincontroller.ini file to change the max_coil_dur line from 8.00 to 25.50 to get the 50% duty cycle recommended.
Okay, I've changed the file. And double checked that it's been changed. And restarted TS (even shut the laptop off overnight and restarted it before trying to reset the dwell duration). But when I go to try to change the max dwell duration in the TS dialog, I still get the "Can't change... Max allowed setting is 8.00" (or whatever exactly it says).
It's TS 2.0.8 with MSII Rev 2.905 (no, I'm not interested in running MS2Extra). Is this something where I need to have the laptop hooked up to the MSII to change?
