Have a problem , my son threw a rod in his 95 gtp ,I had a spare 3.4 to go in my fiero ... does any one out there know if this is possible? my mechanic says there is a possibility of electrical or sensor problems...thanks for any input
replace 95 3.4 with 92 3.4
92 into 95
I just completed the reverse swap. 95 into 92. The timing cover was different at the alt. I had to use the alt. from a 95 as it mounts differently. Also the duct was different. The 95 has an extra cam/crank sensor. Use the map setup from the 95. The pcv is different. The 95 does not use an external oil cooler line and the bypass housing at the radiator hose is different. Hope this helps.
