In looking at the wiring diagrams, the 24X sensor does get ignition power, but it comes directly fro the PCM through lead #70, The 7X sensor is the one that plugs directly into the ignition control module and it is a two wire system that generates somewhere between .5 and 2 volts AC. The 7x does not get external power.
I marked the reluctor wheel at the various firing positions and I pulled the fuel pump relay to limit the fuel flow. Shining the light on the wheel and trying to figure out what is happening is tough, but #1 was firing right at TDC. Here's where it get weird: #2 looks like it usually fires at #2 TDC, but I know I saw it fire a couple times at #1 TDC. If so, it is firing 60 degrees advanced, and that does make it hard to crank. So, it may come down to a defective ignition module.
I know the car was running OK when the cam broke and caused the death of the original engine. The car has not run in a year, but the electronics should not care. I took it out and see that it consists of 3 coil packs than slip onto the ICM base. The only thing I can figure at this point is that the electronics portion has a bug that is causing it to fire more than one pack at the same time.
