Engines require three things, fuel air and spark, here, I get fuel to the engine.
In the past on my 660s I've used a stock fuel rail and regulator, well, I had tried an MSD regulator that I was not impressed with and replaced pretty quickly with a stock regulator that I modified to be adjustable. This time I have plans of really increasing available flow through the fuel system, so this is what I shall call "the get it running set-up".
On the previous engine I had a custom fuel rail made, since the stock fuel rail was fugly and wouldn't flow as well as I needed it to, and also limited me to barb style injectors. In that system I had an Aeromotove FPR, that worked well, so I wanted to retain that with the 660. To do this easily required some -6 AN fittings at the fuel rail. Now I know there are expensive adapters available to do this, but I am cheap, and I plan to modify the fuel rails even more in the future, so it made the most sense to weld on some AN fittings to the stock rail. I used a couple 3/8" NPT to -6 AN fittings, instead of the "weld on" type since these were cheaper, if I had to buy them, but I also had a pair of these already, so it made it easy, and cheaper for me.
Installed in the car. I attached the FPR to the strut tower, because I wasn't happy with anything I came up with for mounting it on the engine itself.
I've Got The Power
Next up was wiring. I retained the ECM and harness I was using on the previous engine, which is a 1227749, with a modified harness from a 1988 Cavalier. This is actually the third 660 this harness has been attached to, and third vehicle, if you include the donor car and engine. I used this same harness in my Jimmy years ago. This set-up has been running the L28 for the last 6 years, so all I had to do was modify for the LX9.
Funny enough I didn't have to modify each injector length, since they kinda fell into place, I just had to shorten some wires, and extend only the O2 sensor wires to get everything to fit how I wanted. I aldo had to add some wiring for the alternator, since I am using a Toyota alternator, instead of the GM alternator I was using on the L28.
In these pictures is where I pulled a couple wires out of the vehicle harness to be connected differently, or at different points then where they were originally.
I had intended on using an old hot rodder trick for the starter, where a Ford starter solenoid is used to give power to the starter, on both the heavy feed and the small signal wire. I have done this in the past without issue, but this time it held the starter on for a couple extra seconds, so I ended up changing to using the Ford starter solenoid as only feeding the higher current supply and triggering the starter more conventionally otherwise.
Here I have the loop that is now removed:
Ford starter solenoid, I may remove this and wire it a little differently now, because of how I actually have this connected, but it's working well as it is.
