Does anyone offer polyurethane bushings for my '94 cutlass supreme? I am most interested in motor mount bushings,but any suspension bushings would be great as well. I can't seem to find any available. Thanks.
Mark
No poly motor mounts, but you should be able to get a solid rubber motor mount from NAPA. Check out their page.
Warning - My solid motor mount DID NOT FIT in my engine bay! I don't know if they just messed up on my mount or what, but the bottom bolt studs didn't line up with the holes in the body... I had to grind on my body to make them fit.
As far as suspension goes, you can just get Energy Suspension poly bushings to replace swaybar bushings... that's about it though.
SpudFiles
Blast vegetables and whatever else you can think of! Theopia
Enjoy life online.
I have a box of bushings for the control arms and rear lateral arms (no trailing arm). $50 and they are all yours. I gotta locate them if you are interested.
PCguy,thanks for the info on the solid rubber motor mount. I'll definitely check that out.
sappy,I don't know what direction I want to go as far as suspension just yet. Are those bushings poly or rubber?
Thanks for the replies fellas.
