4t45e Torque Converter Not Staying Locked
I don't have a way to checking the temperature. Will a code scanner be able to check the temperature?
don't suppose you have a way of monitoring trans temp?
it sounds like the normal PCM unlocking of the TCC due to high temps, if so, pipe in an auxiliary trans cooler.
Well if you read my last thread about my oil pressure gauge and the spinning of a bearing I have an 05 LA1 in my 03 Grand Am GT. So after the swap I noticed that my torque converter will not stay locked. When I drive it first in the morning it will shift fine and lock up. Then after a few minutes it unlocks and rpms go up. After a while it will lock but unlock again. Fluid level is ok, it's not brown or burnt. I have 94000 on the tranny. Can anyone tell me what the hell is going on here? I heard there was a PCM flash to correct this.Tags: None
