Originally posted by gectek
View Post
4t45e Torque Converter Not Staying Locked
That sounds good man, I'll let you know if I need to replace the thing.
Let me know what you want to do, as i provide rebuilds on the FWD trans. I can have a core built in a few days and on its way in any form you wish honestly. Built mild to MANLY!
Yeah, it's almost out of warranty so I think they're giving me the run around to be honest. F- it. It hasn't done it in days so I believe a good fluid change and TC drain will do the trick. If not I'll replace the MFer.
Yeah, I have a warranty on the parts at least. I told them they needed to drive it longer than eleventeen seconds. It's not throwing any codes and they couldn't reproduce the problem so they're not touching it.
doesn't even sound like they went anywhere near the trans. probably couldn't reproduce the problem so they went on to the other stuff.Originally posted by pocket-rocket View PostThey poked you for $500 and didn't even bother changing the fluid/filter?
should have just told them you would fix the stuff later. could have saved yourself a couple hundred. doesn't sound like they took you for a ride on the price. the wheel bearings run about $150 and the tie-rods are $50ish a piece. plus the alignment was prob $60-80.
Yeah but I don't particularly like working in the cold. The problem has reared it's ugly head again, intermittently. It will be fine and unlock for 5-10 miles and lock up and be ok. Need to changed the damn fluid...
I would have told them not to touch anything else and replace it all yourself.
A little update here, I brought it to the garage and they couldn't reproduce the problem. It hasn't done it since, it's normal now. I'm stumped but I'm going to change the fluid anyways. Although I did leave the garage with $500 bill, wheel bearing, tie rods, a bushing and an alignment.
Yeah... It's going to the dealer Monday morning. I'll let them deal with it for free.
Then you have alot more going on than you thought. Pull pan, change filter, add new fluid, can help alot. Check the magnet in the pan.
I know, but after I pass someone the transmission will not lock up. The TC will stay unlocked for some time. Usually is locks back up the next time I drive it.
