Are the axles different between the auto and the manual? It looks like they would be, the drivers side at least looks like its a lot longer. Also, where does the VSS plug into on the 5 speed? I got this trans from a 1990 Grand Prix 3.1 5 speed. That should be the 284, correct?
Couple ???
several people have used the 3.4 dohc with the 282 in the fieroOriginally posted by goatmanWill the 282 work well with the 3.4 DOHC without any mods? If not I'll have to see if I cant return it, because I told the guy specifically what I wanted.1995 camaro 3.4 5-speed
What do I have to do to get it to work in a Lumina? I can see that I'll need a new mount for it, since the mount for the auto is nothing even close to what this needs. Will I still be able to use all the linkages from a 5 speed Lumina for this trans? Cause I already have all that sitting at my moms.1993 Lumina Z34 - Broke Yet Again
What the flip Uncle Rico!?!
So I hear .. do they change gears or "build it up" or slam it in stock?Originally posted by Wolfseveral people have used the 3.4 dohc with the 282 in the fieroOriginally posted by goatmanWill the 282 work well with the 3.4 DOHC without any mods? If not I'll have to see if I cant return it, because I told the guy specifically what I wanted.
Are their gear ratios on the 282 comparable to the 284?
Sorry if Im hijackin, but thought this info might be pretitent to goatman as well as others
JayNew member of 200,000 mile club as of May 16, 2005
I was gunna ask the same questions, so no worries pepsi. Im gunna call the guy tomorrow, ansd see if he cant find me a 284, cause thats what I wanted in the first place, but if not, I'll just keep this one and use it as best I can.1993 Lumina Z34 - Broke Yet Again
free bump .. wondering your status goatman ..
Gear ratios:
The Getrag 284 (attached to 3.4L DOHC 91-93) gear ratios:
1st...3.46
2nd...2.28
3rd...1.48
4th...1.09
5th...0.72
FDR...3.67
The Getrag 282 for a WBody V6 (the one you got)
1st...3.77
2nd...2.19
3rd...1.38
4th...1.03
5th....0.81
FDR...3.61
This info is from this site .. on left in gray under "Transmissions"
So when I get a clutch for this, do I get one for a Lumina 3.4, or the GP 3.1? Also, how similar is the wiring between the 282 and 284? If its gunna be a huge pain in the ass to get this trans to work, I may just try and find a 2841993 Lumina Z34 - Broke Yet Again
lol My VW Buggy is like that. I can park the car with the starter
I know a girl who had a VW bus. She stalled it and instead of starting it properly she used the starter to get across the intersection. By that time it was going fast enough the engine started again.
