So far in my posession...
1)Aluminum cradle bushings.
2)3400 coil pack (thanks Sappy)
3)TCE 7X wheel and sensor mount (thanks Sappy)
4)Innovate LC-1 wideband
5)Innovate SSI-4 4 channel sensor interface for datalogging
6)3500 complete w/o accessories but with extra exhaust manis for experimenting (Thanks ForcedFirebird)
7)7730 ECU
Still need..
1)3400 style ICM
2)Some method of connecting the 3500 injectors to my harness and firing them properly
3)Some form of motor mounts
4)New clutch, really need some advice on this one, Merlott recommended Centerforce dual friction cause his worked like a charm, one Fiero friend with a 4.9 caddy swap absolutely raped his centerforce and hates them, I just need something to hold a fair amount of abuse on a stock 3500 with..
5)Neutral flywheel, anything from any 60*v6 from 88+ will work?
6)Wideband 02 gauge for in car monitoring while not logging, why not?
7)A Romulator to speed up tuning the car Ostrich 2.0 I'm thinking?
9)7x sensor to work with the TCE kit, I might need a part number here for something that will work with my Fiero harness/7730
10)Devise some way of getting an alternator mounted in there, no idea which alt or which brackets to use at this point
This is all I can think of for now. I've got a 7730 ECU and figure I should do away with the tedium of burning and pulling chips and just buy a romulator. A 7730 with lots of data logging should produce the most well dialed tune for the money I'd imagine?
I will continue adding more in edits if I think of anything... gotta get the ball rolling on this, drag races are from August 7th-9th and I would be FLOORED if I could even take the car to watch let alone compete.
Questions or comments!?
7)7730 ECU
Still need..
1)3400 style ICM
