I bought the DVD off ebay, and wrote down everything important (to me).
58x timing sensor (60-2)
LS1 piston size
Hollow tube cam like the 3400 cams
25 degrees max advance and retard from the home position
72mm TB
The intake tuning valve is open most of the time. It is closed for 1600-3800 RPM and high load.
Multec 3.5 injectors (tri coil, no internal o rings, less restrictive internally)
Tools
EN46745 Piston Pin Remover for the full floating piston setup
EN47719 Leaf spring tensioner tool for timing chain
J33049 Cam bearing installer kit (same as other 60V6 engine)
J43690 Rod Bearing Checker and J43690-100 is the adapter kit
J5892D and EN47823 Valve spring removal tool
LS1 piston size
72mm TB
Tools
