Changes from 95 intake to 2000 intake
  • Changes from 95 intake to 2000 intake
    Hi im just trying to refresh my memory on what needs to be done to the new style 2000+ intakes to fit with a 95 setup.
    1:Tap out heater coolant hole to fit 95 thread
    2:I think the lower intake already is ground down for the rocker clearance
    3:I think 2000 had a crank case vent behind the throttle body on the top of the upper plenum that i have to plug cause i have a small filter on it now.
    Anything else let me know.
    1995 Cutlass Supreme 3100 SFI
    Cold Air K&N Filter
    58mm TB
    Dynomax Duel Exhaust with Performance Catalytic Converter
    FFP Underdrive Crank Pulley
    1/4 mile 15.65 at 90.8 mph
    I guess nobody knows so ill tell ya what i have to change.
    Cold Air K&N Filter
    58mm TB
      i think you have it pretty much summed up right there, thats why no-one has responded.
      i cant think of anything else at the moment right now.
      Colin
        OKay good i thought maybe i stunk or something.
        Cold Air K&N Filter
        58mm TB
          dont forget to get the proper gaskets for the new 3400 intake, to take advantage of the 3400 taller intake ports, get the 3400 gaskets.
          Colin
            hey Jweir22, found a solution for the upper intake EGR mounting problem:
            As some of you know, I made an adapter plate for the 2000+ intake manifolds. While making it, I took some pics, but unfortunately I forgot to take any during some of the steps, so I'll have to explain the best I can. I made a plate that is 1 inch thick. It cannot be any thinner, as the hose...
            Colin
              Thanks i was thinking of something like that i have to take a look at my EGR.I think i'll make it look sweet so it looks professional, i'll make one and show some picks and maybe i could make some foer people that don't have access to a machine shop.
              Cold Air K&N Filter
              58mm TB
                Wouldn't it be even easier if i just bought a 2000+ EGR valve wouldn't it just bolt on?
                Cold Air K&N Filter
                58mm TB
                  It would probably bolt on, but the electrical connection I'm almost sure is different. And, EGRs usually run $100+, so the price difference is pretty big.
                    Well i found one for 35 bucks how can i tell if the connection is the same before i buy it? Does anyone have a 2000+ EGR Valve that can check and see what the connection looks like? That would be great if some one had one.
                    Cold Air K&N Filter
                    58mm TB
                      Better yet if its 3 wires could'nt you just trade connectors and wire it up.
                      Cold Air K&N Filter
                      58mm TB
                        Anybody know the difference form a digital or a linear EGR?
                        Cold Air K&N Filter
                        58mm TB
                          digital EGR valves are very expensive... the digital one for my car was over 200$... gurrrr
                          3.4L camaro some goodies
                            The egr for the 2000+ has 4 pins does anybody know how many pins a 95 3100 egr has get back to me.Just would like to buy one and bolt it on with no plates to make.
                            Cold Air K&N Filter
                            58mm TB
                              the 2000+ EGR willnot work, there are 3 wires for a 95 egr and 4 on the 00+. I had an adapter plate made for mine and it works great, and I didnt have to hack into my wiring harness.
                              Mine is kinda basic looking as I made it from some scrap steel laying around. I would love to see a billet alunimum one.
                              You will of course need EGR gaskets for both EGRs and longer bolts to hold it on.
                              1995 Monte Carlo LS
                              3400 SFI 60v6
