what is the firing order of a 1992 firebird with a 3.1? how do you adjust the valves?
firing order
RE: firing order
'92 Firebird is gen1 iron heads, so they should have adjustable rockers/studs.
Here is the procedure:
- Rotate the engine so the cam is on the base circle for the cylinder you are working on
- Rotate the pushrod with your fingers while tightening the rocker adjusting nut
- When the pushrod stops spinning, this is the zero lash point
- Tighten but another 1-1/2 turns to preload the lifter
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
what i did was put a new set of heads on the new engine. i put new rockers arms on it and i am having a problems with getting started on what to do. i did a swap with the engine and put it in my s10. i used the tbi intake instead of the mpfi because of no computer changes would be needed and i am backfiring through the tbi. i think i said all of this right, haha.
Your distributor is 180* out.
Put number 1 on TDC COMPRESSION STROKE and set up like this
