LIM torque confusion
roxtro- where are you getting all these different specs? That gasket set should have a paper included- use the specs that come with the set. When I did the LIM job on my '01 Lumina, the specs in that new-style Felpro set were the same as Scoopy just listed a couple posts back. It's worked fine for a year and a half so far.
I dont have the sheet but if someone can scan it before I get to one, please do so. Then it can go in the wiki
here is what is says on an ebay listing. listing will also show you which one of the bolts need what torque spec.
here's what is says though
Tighten the vertical lower intake manifold bolts (1) to 7N·m (62 lb in).
Tighten the diagonal lower intake manifold bolts (2) to 7N·m (62 lb in).
Tighten the vertical lower intake manifold bolts (1) to 13N·m (115 lb in).
Tighten the diagonal lower intake manifold bolts (2) to 25N·m (18 lb ft).
Ive got a 2000 malibu LS 3.1 alum. head, IM using new style FELPRO gaskets
Ive found 3 DIFFERENT torque specs
#1. 115in lb all 8 bolts
#2 9ft lb 4 inside bolts and 18ft lb 4 outer
#3 18ft inner and 24ft lb outer
???????????? THANKS in advance for some helpLast edited by roxtro; 06-29-2007, 12:28 AM.Tags: None
