re
I thought I had this issue solved..... but its been a recurring issue. I would drop the tank, clean rust from under the pump, car would run fine for a while.... then repeat. Well, last time I dropped the tank there was almost no rust under the pump this time, so I broke down and bought a new Delphi for 90 bucks. The new pump didn't help at all, so now I am back to square one. The car runs terrible when the weather is cold, say 50* or colder, the car hesitates pretty severely until it warms up. It will stumble when it starts up in cold weather, and taking off from a dead stop takes a lot of slipping of the clutch. Shifting into 2nd is embarrassing as well, because the car nearly dies unless you slip the clutch a lot. The only thing I can think of anymore is the fuel pressure regulator, so I guess that will be the next stop.
