the rocker arm threads for cylinder no. 5 on my moms venture pulled out. i read somewhere online the threads are an m10x1.25, but that is way to big. anybody know the thread size/pitch off hand? its a 2003 venture 3.4. thanks
3.4 rocker arm bolt heli coil
From this post:Originally posted by 02GT_Skyhigh View PostOk, purchased a Helicoil set for a 10mm 1.5 thread
Posted in this thread:
Although I do remember there being two different rocker bolt sizes, 10mm and 8mm. Not sure what the thread pitch would be on an 8mm. I would probably say 1.25 like the 10mm, but I would take the rocker arm in with you so they can get a thread pitch/bolt size off of it to be sure.-60v6's 2nd Jon M.
the left side rocker arm for cyl. no.5
the right side rocker for cyl. no. 5. and when i took this rocker arm bolt out the threads stripped out on the bolt, so i will probably have to helicoil this one too. i already got a new rocker arm and bolt, but i could not get the pushrod out of the rocker without breaking the end off.
Oh my gosh I am so sorry my friend!
But I DO feel your pain! read my thread and I hope it helps!!
Best of luck, PM me if you have and questions.2002 GAGT
- Street/Strip 3500 Heads - WOT-Tech Comp 3500 LIM - K&N Drop In - Magnaflow Cat and Muffler
- Eibach Lowering Springs - Bridgestone Potenza 225/35/r16 - Drilled and Slotted Rotors - Ceramic Pads - KYB GR-2's
- Big 3 Electrical Upgrade - Kicker SX650.1 Monoblock - Kicker CVX12"D4 Sub
- Ported Box @ 1.88^ft to 34hZ - Alpine CDA-9884 - Cadence 6.5" Component's
http://www.cardomain.com/ride/391881...am-gt-sedan-4d
thanks. this happened to my moms van before on cylinder no. 3, but that was covered under warranty. i hope i can fit my drill under the cowl, i do not want to take the head off.Originally posted by 02GT_Skyhigh View PostOh my gosh I am so sorry my friend!
I had to helicoil the side of the head when I got back putting it all together. The threads for the pulley tensioner stripped as well. I couldnot fit my drill back in there and I had just put the while top-half back together.Originally posted by safarimike View Postthanks. this happened to my moms van before on cylinder no. 3, but that was covered under warranty. i hope i can fit my drill under the cowl, i do not want to take the head off.
So what I did was use the bolt for that thread and tighened it down until I had 'cleared' the threads. I then used the Helicoil tap and ran it in 3/4 turn then cleared it out, then 3/4 turn in, then back out,.... It was slow going and tedious work, but not as bad as taking the whole motor apart. Just be very very careful if you try any above methods, If you break the Helicoil, your screwed.... lol2002 GAGT
I've seen this happen on a few heads before... I just hope the 3500 ones are made just a little bit stronger... I have yet to have this happen, however I am helicoiling every single header bolt thread since those are getting worn out and ready to pull free. And yes motor is out since there would be no way in hell to do that in the car.
I busted out two of them on my wife's grandmas '04 or so century I think it was.
I doobed and forgot to loctite one of the helicoils also.
That was about 5yrs ago,saw the car last week and still going strong.
My wife's aunt drives it now,it's got 150k+ on it with no issues
