First some history:
-3500 LX9 motor swap (all stock)
-3400 exhaust manifolds
-2.5” exhaust, high flow cat, stock mufflers off a 97 GTP
-Modified to fit 3.4 dohc throttle body (63mm I believe)
-1997 Lumina air box (from 3100 motor) and paper air filter
-3400 fuel injectors
-GEN II/III ICM/Coil packs and aftermarket external crank trigger
-1997 Lumina Dogbone Mounts. 3x00 solid motor mount and, in addition, a 3.4 dohc rear mount
-Getrag 284 5 speed manual
-tuned by Ben of WOT tech
Symptoms:
-Hot idle is steady, however engine ‘bounces around’ just a bit
-5th gear, under 2500 rpm (say 60 mph), and a small load (passing someone) causes a lot of vibration. Once it exceeds 2500 rpm (over 65mph) it smooths out. At 70mph and above it runs great. I can also cruise at 60 mph in 5th without any shakes so long as I am maintaining speed and not attempting to accelerate.
Potential Cause:
-Ignition problem
-Fueling problem
-Motor mount problem
-Issues with the ecm Tune
What I’ve tried so far:
-New spark plugs and wire set
-Swapped ICM/Coils with a spare set
-Ohm tested injectors
-Ben assures me the tune is looking good
So… there you have it. At hot idle, I can see the engine bouncing around a bit, I notice it on the accessory side of the motor, I can see the rubber in the dogbone mount allowing the motor to dance. At idle it is moving around +/- quarter inch. BUT, at speeds under 65 mph and in 5th gear the vibrations feel much much worse. And something like 50mph in 5th, forget about it!
Any thoughts? Should I try to shore up the passenger side dogbone mount? If so how? I don’t see myself shelling out $80 for a poly dogbone, especially since I don’t know if that will fix the problem. Do you think I have another problem?
Driven normally it is running pretty well, it is smooth and quiet. It has a bit less torque then I expected from 3.5 liters and the WOT performance is something between a GenII 3.1 and a stock 3.4 dohc. In a drag race, I would hands down give it to the 3.4 dohc. But, cruising around town, 30-45 mph, it is quiet, smooth and I think fairly efficient. The injectors are of unknown mileage. I purchased them on ebay, they were listed as 3400 Monte Carlo injectors. They do ohm out ok, but I’m not sure if they are flowing correctly. The 5th gear vibrations are really what is keeping me from driving the car regularly right now.
Symptoms:
Potential Cause:
-Ignition problem
-Fueling problem
