my 3.1L in my g/a doesn't want to get warm. I put a new therm (oem ac/delco) about 1.5years ago, and worked so so... I was getting mad last night because it wouldn't warm up beyond the 1st notch on the temp gauge. (between 100 and 220). When I first got the car, it stayed below the 220 mark... (probably around 200). So, I changed the therm and replaced the o-ring and bypass on the water pump, used rad flush, and filled it with new fluid. it gets warmer now, but still doesn't seem like it is normal.
also, I pulled the front 3 plugs and the middle one was white. Oil looks like oil (no water). I'm wondering if I've blown a head gasket or something..
plus, I keep getting EGR solenoid failures; I've replaced the EGR, O2, the MAP was reading normal, and I replaced the temp sensor behind the therm housing. I also pulled the TB and clean the EGR passage way, b/c it was blocked almost 100%. I also swapped ECMs too, no luck..
I've guessing the EGR might have something to do with the temp problem, but I am not sure..
any suggestions?
any suggestions?
