Allright Guys,
Sorry this is a long post but I need help badly! I'm ready to push this *&%#@ car in the lake! First, this is my wifes '96 Monte Carlo. It didn't have oil pressure, and lotsa miles so I pulled the engine. The owner (a buddy) of the wrecking yard told me to find a mtr and I could have it free. The closest I found was a '95, but the starter was busted and I rolled the dice and didn't pull the pan. I put a starter on it at home, and did a compression test, all good. I installed it and it had spun 2 rod bearings, stupid, stupid, stupid!!!
Got burned, so I went and got a rebuilt long block. Cleaned engine bay and all accessories spotless, and installed the long block. Just cranked it and it sounds like crap. Looks bad ass, though.
Mtr is rattling, sounds like bottom end, and my first guess would be the timing gear was installed off a tooth? I know muscle car V-8's w/carbs but not great on fuel injection. With the oil filler cap off I can see oil pumping well in the rocker arms. I reused my roller lifters, but didn't notice one mtr was roller rockers and the other was reg . The core I took them was the 95 without roller rockers. The 96 had them. I tried to put them on but the boss on the heads didn't have a slot so I just stayed with the non-rollers. I used the push rods from the 96. QUESTION: Are the push rods from non-rollers a different length than rollers?
Tomorrow, I guess I'll do a compression test on the NEW long block and see what it has. I was thinking about changing some of the injectors because it has a miss I can't get out. The ironic thing is the used mtr w/spun bearings ran good, just had the bad knock! That's why I'm confident all my sensors and coil packs are good because everything ran alright on the two previous mtrs, within the last two weeks. Does anyone have any thoughts or input on a problem I'm not seeing? I've got that sick feeling it's just a bad mtr that I'll have to pull back out, I just don't like that rattling and it won't idle. I sprayed starter fluid all around the intake, top & bottom and it didn't change the RPM's. Any input appreciated...
