Hi all,
About 3 weeks ago I had coolant spewing into my oil, thought it was a head gasket but it turned out to be a broken head bold. Got the heads refinished with a valve job.
Got it all back together and running but i am hearing constant knocking.
Check out this video, you can hear the sound clearly.
VIDEO
I took the front valve cover off and noticed a valve wasnt even opening. could this sound be comming from the lifters, rods, and rockerarms not building up sufficient pressure because the lifters got clogged with all that coolant. I will be taking off the intake manifold and cleaning the lifters out.
I just want to know if i will be waisting my time and if something worse happened that caused that head bolt to break. Requiring me to remove the engine.
Thanks for any help on this one!
VIDEO
