I am rolling a few ideas through my head of what i want to do this winter. I picked up a 3400 for my 2003 Malibu, and planned on either doing a Milzy Motorsports Stage 1 or stage 2 kit, or getting one of the 3500 top end swaps from here. That descison will all boil down to money, but if i went with the 3500 top end swap from the store, I was thinking of putting in a new camshaft. I know from my previous experience that a gen 3 3100/3400 use the same camshaft, what i was wondering is if the 3500 in say a 2005 Malibu is different, and if it is different, will it go into a 3400? I would assume that since the 3400 was rated at 175hp and the 3500 was rated at 200hp that the camshafts where different. I didn't want to go to crazy with the setup, but if i went with a topend swap i am sure a new camshaft would help that top end work better. I used to work at dealership and had access to all this but i dont work there anymore. Any help would be greatly appreciated.
Camshaft question?
Tags: None
actually one more question, with a 3500 top end swap, will i be able to use my stock injectors and fuel rail?
ok, i found out just now that an 05 3500 uses the same camshaft as a 3100/3400 (part # 12567117), does anybody now the specs of the stock cam? also if anybody wants a good website to get part numbers from, go to
its an online GM parts catalog from Jim Bradley Pontiac in Ann Arobr, MI. I have been trying to figure something out but am kinda confused, does the 3500 heads on a 3400 raise or lower the compression ratio? I was under the assumption that a 3500 head has a smaller combustion chamber then a 3400 head which would lower compression ratio, but then i thought i read on here somewhere that the 3500 heads lowered the compression ratio, if these heads lower the compression they would be good for turbo or supercharged applications, and i don't plan on doing either, anybody know for sure?
Its not fully up-to-date, but here is the cam info:
3500 heads have a larger combustion chamber and will lower the CR of a 3400 to ~9.1.
GMPartsDirect also has an online parts catalog for PN research.-Brad-
Allow more and better flow into the combustion chamber and have a better chamber/quench design. The CR change really isn't that significant.-Brad-
if i did a 3500 top end swap do i use my stock injectors and fuel rail? how much power is this swap wurth? I have a tuned PCM, cold air intake, MSD igintion, and dynomax muffler, when i do the motor i plan on getting some s&s headers
With the 3500 swap you use your current fuel rail.2000 Grand Am GT
2011 Chevy Impala
im not too sure if the 3400 headers will bolt up to 3500 heads. Anyone got input on that?Lots of mods cost lots of $$
http://www.cardomain.com/ride/2598719/1
I am running them on my 3500 heads now.Originally posted by alerored04 View Postim not too sure if the 3400 headers will bolt up to 3500 heads. Anyone got input on that?
They fit just fine.2000 Grand Am GT
2011 Chevy Impala
oh cool. Wasnt sure if the exhaust ports were the same.Lots of mods cost lots of $$
Originally posted by alerored04 View Postoh cool. Wasnt sure if the exhaust ports were the same.
Here is a pic of my front TOG header with the 3500 gasket layed over it.
2000 Grand Am GT
2011 Chevy Impala
I know the CR of the 3500 is 9.8:1. So they must use different pistons to gain the CR. They also redesigned the exhaust maniflolds as well. Much better flow.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Its a returnless setup, so there would have to be modifications made to the entire fuel system.-Brad-
