Camshaft question?
  • Camshaft question?
    I am rolling a few ideas through my head of what i want to do this winter. I picked up a 3400 for my 2003 Malibu, and planned on either doing a Milzy Motorsports Stage 1 or stage 2 kit, or getting one of the 3500 top end swaps from here. That descison will all boil down to money, but if i went with the 3500 top end swap from the store, I was thinking of putting in a new camshaft. I know from my previous experience that a gen 3 3100/3400 use the same camshaft, what i was wondering is if the 3500 in say a 2005 Malibu is different, and if it is different, will it go into a 3400? I would assume that since the 3400 was rated at 175hp and the 3500 was rated at 200hp that the camshafts where different. I didn't want to go to crazy with the setup, but if i went with a topend swap i am sure a new camshaft would help that top end work better. I used to work at dealership and had access to all this but i dont work there anymore. Any help would be greatly appreciated.
    [url]http://www.cardomain.com/ride/2367486/1[/url]
    actually one more question, with a 3500 top end swap, will i be able to use my stock injectors and fuel rail?
      ok, i found out just now that an 05 3500 uses the same camshaft as a 3100/3400 (part # 12567117), does anybody now the specs of the stock cam? also if anybody wants a good website to get part numbers from, go to
      its an online GM parts catalog from Jim Bradley Pontiac in Ann Arobr, MI. I have been trying to figure something out but am kinda confused, does the 3500 heads on a 3400 raise or lower the compression ratio? I was under the assumption that a 3500 head has a smaller combustion chamber then a 3400 head which would lower compression ratio, but then i thought i read on here somewhere that the 3500 heads lowered the compression ratio, if these heads lower the compression they would be good for turbo or supercharged applications, and i don't plan on doing either, anybody know for sure?
        Its not fully up-to-date, but here is the cam info:
        3500 heads have a larger combustion chamber and will lower the CR of a 3400 to ~9.1.
        GMPartsDirect also has an online parts catalog for PN research.
        [SIGPIC][/SIGPIC]
          ok so if the 3550 heads lower CR that much, then how can they improve performance that much?
            Allow more and better flow into the combustion chamber and have a better chamber/quench design. The CR change really isn't that significant.
            [SIGPIC][/SIGPIC]
              if i did a 3500 top end swap do i use my stock injectors and fuel rail? how much power is this swap wurth? I have a tuned PCM, cold air intake, MSD igintion, and dynomax muffler, when i do the motor i plan on getting some s&s headers
                With the 3500 swap you use your current fuel rail.
                [b]2000 Grand Am GT[/b]
                [b]2011 Chevy Impala[/b]
                  im not too sure if the 3400 headers will bolt up to 3500 heads. Anyone got input on that?
                  [CENTER]Lots of mods cost lots of $$
                  [URL="http://www.cardomain.com/ride/2598719/1"]http://www.cardomain.com/ride/2598719/1[/URL][/CENTER]
                    I am running them on my 3500 heads now.
                    They fit just fine.
                      oh cool. Wasnt sure if the exhaust ports were the same.
                        Here is a pic of my front TOG header with the 3500 gasket layed over it.
                          I know the CR of the 3500 is 9.8:1. So they must use different pistons to gain the CR. They also redesigned the exhaust maniflolds as well. Much better flow.
                          Andy
                          [SIGPIC][/SIGPIC]
                          fastest 1/8: 10.19@ 67.17
                          fastest 1/4: 16.16@ 82.70
                          62mm TB, 1.6 roller tip rockers, Ostrich 2.0, UD pulley, TB heater bypass, K&N, 180* stat, No cat, 99Grand AM dual cooling fans. 4T65E swap FDR 3.69, EP LSD, F.A.S.T. transmission controller, TransGo shift kit.:cheers:
                            Why not use the stock 3500 fuel rail? Just curious if there is an issue with it?
                            -- Scott
                              Its a returnless setup, so there would have to be modifications made to the entire fuel system.
                              [SIGPIC][/SIGPIC]
