Now I need to get custom length pushrods for my engine since I got a Milzy stage one cam. I know on his site that it says you dont need pushrods but if you measure the base circle of the cam from a stock one its smaller, therefore you will loose hydraulic preload on the lifters if you stick with the stock size. Now my question is, can I go and order a set of pushrods that are the base circles radius difference, longer? If your confused I'm thinking that I measure the base circle, get the radius and then just add that to the length of the stock pushrods and I should be set right?
I know how to check valve geometry but nothing else is changing except for the cam base circle. I could understand that I would need to do much more research if I decked the heads, or used longer valve stems or something weird like that but the only change here is the cam.
Any info appreciated.
