where can i find them? what size are the valves? how much am i looking to spend on ss valves?
3500 stainless steel valves
1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..Tags: None
if i wanted to replace my stock valves with ss valves what sizes would i get?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
are the 3500 valves the same size? what companies are you all buying the valves from?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Federal Mogul has a good price on OE valves and seats and when I get back on a fast net service I'll try and post their pdf of all of their valves listed in numerical order which includes all of their important specs. According to GM the valves in the heads designed for methanol use have a special treatment making them a bit tougher due to the need to be corrosion resistant so they are probably pretty good for extreme conditions.Originally posted by rickykline View Postare the 3500 valves the same size? what companies are you all buying the valves from?
Federal Mogul Pdf Files For Valves
Here is an excerpt taken from GMs site, ethanol not methanol sorry, though the effects maybe similar. I recall reading a more updated source on it that mentioned some kind of processing that makes them more resistant to corrosion.
"The standard valves and valve seats are durable enough to withstand the long-term corrosive effect of E85 ethanol, so no upgrade is necessary"
The pdf files make it much easier to see what larger valve sizes may work for the heads.Attached Files
