I'm in the planning stages of building a 3.4L and need some info.
First off the engine will be ran on propane and will be installed in the RWD position.
These are my wants for the build.
11.0:1-11.5:1 CR.(LPG 105-110 octane)
Gen III heads and intake.
Needs to have a Dizzy.
1.6 SB roller rockers.
3.4L or 3400 block?
The Crane "H-272-2" PowerMax camshaft.
Can the 3400 with the top intake reversed be setup with a distributor?
Is there a hole for the distributor in the 3400 block and will a aftermarket cam fit?
I have seen in some posts that the distributor will interfere with the intake if it is used with a 3x00 intake manifold,is this true if so can the intake be modified to let the distributor fit?
Also I'm trying to locate the following specs.
Iron and Aluminum head gasket thickness and bore.
3.4L and 3400 piston CC.
With these numbers I can get a rough estimate of the 11.0:1CR I need.
3.4L or 3400 block?
