because it is a 3.4 liter so it has more displacement=more horsepower
jet or hypertech??
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mile
there's two of em' that say's flash...and they're pretty small.
im'a go to the jy and find some 3100 grand prix's and open up the pcm and look for this code that the online tech told me.
anyway the lg8 (newer 3100) has 175 hp/195 tq.
while the la1 (3400) has the same hp but 10lb torque.....
okay seeing the 3400 has 10more tq, the shop that was willing to do it felt more confident with the lg8 than the la1, he said the la1 whould need a couple things swapped...only thing i know whould need to be swapped is the injectors and buy a 94 l82 egr adapter.1992 nissan maxima se (190hp/205tQ)
programable fuel injection. http://www.bgsoflex.com/megasquirt.html so you don't need to worry about if it's obd1 or odb2...
JEESH!!! just get a 96 harness from the same model car you have SIMPLE
I got an engine harness and modified it to work with my interior one since that changed a little too.
BOTTOM LINE
you CAN'T tune a 94-95 ECM and you CAN'T unsolder connections to make it tunable.
No one has the code or definition file for it anyways.
